yes, first thing is change oil and filter and put the colder plugs in, need to change the idle bleeds and clean up the idle a little then start working on the timing which should clean up the jetting a little before I put the AF sensor in and start charting that.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
