I guess you could put the Z bar in wrong and it would some grief. I think one arm is a bit longer than the other so that would cause the screw to be at its limit.
I don't know about your's but the arm next to the bell on my '69 z-bar has two bends in it. Its wider than the other arm and it has holes for the bushing clip and a hole for the tension spring from the fork.
