I called Jim, and unfortunately he doesn't have an Ainsworth frame. The search continues...
Thanks for the tip.
Rob,
I haven't had time (you know why) to check my own stash, but there is a way to cheat. Normandin Chrysler-Plymouth in San Jose still makes metal frames so if you want a CA frame there you go.
In the meantime I'll work on getting you one from Ainsworth
