Keep what you have and add a pair of "cherry bomb" brand glasspacks alongside the rear leaf springs. O'reillys has em for cheap. the louvers are punched outward & the end nipples do not neck down where they are welded to the main case both of which are beneficial for good flow & they do work.
Put any cheap bullet glass packs in the tail pipes to deal with the drone.
