Originally Posted By hudsonhornet7x
Thanks for the replies. Even though I found a deal on the pistons it seems like I should be looking at bigger cubes.
Have you thought of using a shorter rod length with the longer stroke to use those pistons? work
I have made the mistake of buying a part and then building a motor around that part tsk That is not the smartest way to start on a new motor build unless your absolutely sure you want to build that new motor that way work
