I tinkered with it for awhile before finding the correct set for my m-code 440. It was tight so I started taper grinding the face at the lower edge, took off about 1/8-3/16s to nothing at top, cleared steering fine then. One good face cut on a head grinder will clean it up to make a smooth fit. IMO about the same restriction as the original.
