There sure are many to choose from.They have tubes in 1 inch,1 1/8 and 1 1/2. Must be 6 companies manufacturing them.My present rad uses the original mopar tanks with a high efficiency core that keeps the heap in the 180* range unless it's really hot out and I'm in line at a show to park,then it might creep to 210*
With all the different radiators available,I thought i would bring it to the MOPARTS court and see what you guys had success with.I do not have room for any puller fans , I have 2 pushers that I have been using for years with no problems.
The reason I wish to change is Jenny Craig sitting on my shoulder guiding me on my diet to loose weight.An aluminum radiator should cool better and save me some weight.
What say YE??
