Just by the nature of the design, " two planes" in which the air is trying to mix, " in halves" verus " one bigger" plane, simply cant mix the same, just as each port in any design is often different to match. EGT and O2 sensors are your friend.
With the amount of nitrous your planning on spraying, it wont even matter!
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
