I'd say throw a can of " Motor Honey" in there and you'll be running low 9's in no time..... ![](/ubbthreads/images/graemlins/biggrin.gif) ...of course...always remember to adjust your dual wave dipsticks before each pass. If you run the style with chromium sliders, you need an oscilliscope, but I am guessing you may only be running the standard mild steel version?... ![](/ubbthreads/images/graemlins/apimp.gif) Good luck and go knock it down !
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
