I have a 360 with those lifters in it. It didn't require any clearancing but it is tight, no problems though. My cam is .640ish lift and I had to tube the block.
The lifters BPE mentioned are supposed to be nicer, and the moved link bar obviously helps.
68 Barracuda Formula S 340
