SEM is a paint, not a dye. To my knowledge you cannot dye vinyl
Actually SEM is a "flexible vinyl coating"
You are correct in that you cannot "dye" vinyl since its not porous. BUT, SEM is the closest you're going to get to a product that will change the color of vinyl.
I'd use SEM just about anywhere ... EXCEPT seats. Unless you don't mind doing them every year !!
