Right now I have 235/60r15s on the front and 245/60r15s in the back on my 70 challenger. I used to run 255/70s on the back, and I think I would like to go back to a tall rear tire. Anyone use a tall front like the 245/60? I need to get my Hooker Super Comps up off the ground a little better. I don't want it to have that 4x4 look, but I like to drive it and steep drive ways and speed bumps are a problem. They were even when I was running a 255/70 cause I still had the short front tire. I know I can do a little adjusting with the torsion bars too.
Ehhh....if you have 235/60/15 on the front now, a 245/60/15 will be wider not so much taller (1/2" taller) than your 235/60
