The TQ is a great street strip carb. I like them a lot.
If it is not for you, then a simple carb that will work and work well is IMO a Edelbrock 800cfm Thunder series carb for there adjustable secondary air door.
Just use an Edelbrock thick base gasket to help against the heat of the intake.
