I shoot for the 10 lbs. per 1000 RPM with HOT oil up
My last pump gas stroker had 65lbs at 5000 RPM and up with 180+F degree oil temps, I should have shimmed the bypass spring to get 10 lbs. per 1000 RPM but I left it that way and ended up needing to shift that old rascal at 7000 to 7300 RPM to get it to go as fast as it could realcrazy I never had a bearing or oiling failure issue that I know of shruggy
