I think I can pick up a pair of cheap 452 heads and get them cleaned up and some minor port work done cheaper then I can buy a set of Magnum heads.
A reminder, the 452 heads are BB heads
You're totally right I just realized that after my last post. What la heads are the best bang for the buck? Come to think of it, does anyone know the casting number of the heads that came on a 91 360? Are they better design than previous years? Maybe I can just get them worked on instead of getting different heads, if the intake bolts hole positions are the same too then I could use an eddy intake
