Originally Posted By Challenger 1
The lisle tool I had came with extra rubber sleeves. The snap on tool uses o rings instead and I have never wore one out. Much easier using the snap on tool because the bearings do not catch on the o rings and slide on and off better and you can tell if the expanders are lined up correctly before using it with o rings instead of sleeves.
They're all probably from the same manufacturer.
