That warped thing is a little disturbing. Is it a stock type shaft? If it is, you are starting to push the limits of it as it is trying to "jump rope." Time to step it up to C/M!
My bad, out of round by .008-.010 and enuff to shake the dial indicator pretty badly and also needed ft. weight w/a couple welded on washers. I will install it after business stuff then test maybe later or tomorrow.............. It is CM w/1350 spicers
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
