I would highly suggest cracking the u bolt nuts with a nut cracker then removeing the nuts and clean the bolt threads with a thread chasing die & then the new nuts will go back on like butter (45 lbs on 1/2" ubolts). Road debris fubars the threads on the shanks over time. lightly Snug all 8 nuts evenly then tighten em so the axle lays flat.
