I have installed relays on my headlights for many years now. There are several advantages to relays for our Mopars. Everyone should seriously consider doing it. The only possible disadvantage is that you have to cut into the headlight harness.
There is a person that makes quite a nice relay wiring system for your headlights that is plug and play, no cutting into your harness. I have the kit installed in my Cuda and it makes a big difference. Here is a link:
https://board.moparts.org/ubbthreads/ubbt...tml#Post2231668
