The slight delay on the application of the fronts (holdoff) is more to ensure all four corners apply the brakes at the same time, not so much to reduce pad wear. Under light braking holdoff doesn't even apply.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
