Originally Posted By Supercuda
Originally Posted By mopower440
Originally Posted By Rhinodart
Yes, welded in. You need a 22" core radiator with 3 or 4 rows, or a sawzall... sawzall
Man, i really dont want to swap the support then. will the bigger radiator bolt right in to my original support without hacking it up?
Define hacking it up.
Will it bolt in with ZERO mods, no.
Will you likely have to drill some new mounting holes, yes.
Will it cool more than the one you have, probably not since the airflow is limited by the core support.
So, you can sawzall a bigger opening in the core support, weld in a new core support, or go with a high efficiency radiator for you application.
a high efficiency radiator for my application sounds good, but is THAT a direct bolt in to my stock mounting points and which one is the high efficiency one your speaking of?
