https://www.theturboforums.com/threads/3...it-runs-9-10-11my build and experience with turbocoupe T3's on a 383 and then moving up to something better. Short answer is the little Ford T3's would be ok on a 360 if you got them cheap like I did. Rear mount they'd probably be pretty nice, but like everyone else said, it depends what you have. For all we know you've got tiny fwd dodge units!
I went 'cheap' with twin OEM units and ended up costing myself about 2.5x what I needed to spend when I upgraded because I didn't have time to build a whole new kit to work with a big single. To do over again for cost reasons, I'd do a single and in fact have a 76mm T6 for my Coronet someday.
