Thankyou! If I were you, I'd set your 9" rear up w/ the '68-'70 B body dimensions and use the Dr. Diff offset spring hanger kit to use a 15x10 rim. His kit allows you to bolt in a B body rear and fit a 10" wheel pretty easy.
Mine is a stock width E body rear w/ stock front spring location, but I use the .850" offset rear shackles to get some added clearance and to make the springs closer to parallel. They're wider at the rear in the stock configuration. I use 15x8.5" wheels w/ 5" of backspacing and run both 295-65 radials or 29.5x10.5 slicks on it. Just trimmed the inside of the wheelwell lip to clear the tires.
Here's a pic w/ the slicks on it.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
