RS23U1G Thanks for the lead. Went back out there and adjusted it every which way but I think I have something wrong in the latch assembly. It will almost release but not quite even if I disconnect the outer door handle rod and push the rod till it bottoms out on the latch assembly. Still wont open the door from outside rod but inside handle works fine.
