I know it's coming, so there is sort of an automatic pause with my hand in the application of the throttle. Bring the rpm up a bit, start feeding the throttle, pause briefly when the secondaries pop open, then push it open to WOT...... Let the rpm stabilize...... Start the pull.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
