That's exactly what I needed to see. 2 yellow wires and a pink wire going to the block connector and, of course, the relay is pushed into the connector. I'll have a look around the column to see if I can find the block connector there. Thanks guys!
if memory serves, it's a 3 hole female bullet connector
They are spade lock terminals in a black block connector. I opened the link that you provided and had a good long look at the picture. It's somewhat clear. Anyway, I do have the relay which I was fortunate to get at the dealer and 2 of the terminals are parallel to each other and the pink one is at a right angle to the others. All I have to do is find that block connector, if it's somewhere near the steering column, and plug the relay into it and my ignition light and map light should both come on and time off when the door is open.
