From what I've seen the new Trick Flow cast covers are going to look a lot like my billet covers. If that is the case then you can save a ton of money by getting the Trick Flow cast covers and milling off the Trick Flow name. Not sure when they are going to be available but I've seen some pictures of them and they look pretty good.
