Originally Posted By 73bbroadrunner
No I havnt ran it yet.
If it has been sitting for a while, it's very possible the lifters are no longer pumped up, which makes the duration at the valve much shorter....... And the compression test will read high.
If the 250psi had been observed just after the motor was run and warmed up, and you knew the gauge was accurate....... Then I'd say the cam was like a tooth off(advanced), or the motor is way over 10:1cr(as in waaaaaaaaaaay over).
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
