I use a cutoff tool in a lathe, feed it into the tubing until it just hits the hardened tip then I use the claw end of a pry bar to remove the tip. Depending on how much you want to shorten them, the inside of the tube might be too small....sometimes they're only reamed a short distance in.
The INTERNET, the MISinformation superhighway
