I know the headlights and turn signals are different. If they are attached to the same harness (I no longer remember), than no, they won't easily interchange. Also 79 could have quad headlights.
79 was also some emission controls changes, so even if the engine only harness is separate, they still may not swap directly.
Well, at least it's a bump for you! smile
