it depends on the series of rod as well as the bolt diameter and length. the above mentioned number may be correct, i don't know, but i'd want to be sure if i were you. i have some CA rods that take 90 ft. lbs. post more info about what you have and i'll see what i can find for you.
Dram the only numbers I can see are 150 forged into the side of the cap and j188 stamped on the cap. 7/16 bolt
