I ordered a bolt on 6 Pack hood and bumper from AAR Quality Fiberglass and finally got them mounted up today. The quality on each is good and won't require much prep before paint. I used the factory latch and everything lines up nice. I also got a set of lightweight hood springs from another member and they work great! I haven't decided if I'm going to add a couple hood pins yet we'll have to see. Total weight loss between the two was 42lbs. Next is aluminum bumper brackets.
