Who is the supplier of your new foam?
I did a set for a '71 Cuda that was WAY oversize, the foam came from PUI.
I had to fillet, slice, section & re-glue.
They were close to 30% oversize as a guess.
Everything was provided by the customer. Legendary covers, but I don't know if the foam came from Legendary or not. And yep, the foam is too large, not shaped like the originals are shaped for the bolsters, and not cut where the wires on the covers need to pass through.
How did you go about shaping, slicing, filleting the foam you used?
