Are there any exhaust manifolds that will work with a 383 in a 69 Dart besides the factory big block A body ones? I've heard you can use the B body hi-perf manifolds but need to trim the steering column shaft outer tube back closer to the firewall. Anyone does this or resolved this problem before? Thanks!!
If you don't have the correct manifolds why not use the Schumacker headers.
