Do you use RTV on both sides or just to the valve cover and dry to the head? What works best? Thank you!
Learn from my mistakes.... go with Superformance gaskets. The only set that seal 100% and last a long time. Instructions on torque and how to apply are included. Highly recommended.
I second this. I used Superformance Carbon-X gaskets the last time I had my covers off and it is the first time that I've ever had no leaks at all; they've been on for over a year. I used their pan gaskets too with a windage tray and had the same results, The whole engine is completely dry which I've never had with any gaskets I've used before. Some weep just a little oil but, I always had at least some small leak.
I will never use another gasket for these areas.
