Originally Posted By Skeptic
Originally Posted By DrCharles
This is what I'm using for the bulkhead connector. I used to have an '87 International semi-truck project and it uses the same connector, still working fine after 30+ years. Much less expensive than Cannon, too.
(Weatherpack type contacts/seals).
Those are common on e-bay, I have one for my Barracuda. I plan on using it when I go with the EFI. There are different configurations for number of wires and gauges, so figure what your needs are and shop carefully. twocents
Take a look here:
https://www.diyautotune.com/product/weather-pack-22-position-bulkhead-connector-kit/
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
