A friend and fellow Mopar racer ran two different sets of Holley D.P. mechanical carbs,one pair of 600 D.P. and another set of 650 D.P.. You will need to add a spacer under the carbs. to clear the stock throttle linkage on them, that or cut and trim it as needed thumbs scope
