Yep, A/C motors ran the water pump belt across an idler pulley so only the correct non-A/C pulleys will maintain proper belt alignment when eliminating the A/C. Bouchillon has the pulleys.
http://bouchillonperformance.com/products-pulleys
To do a correct conversion you need the alternator brackets and pulley. Bouchillon has those too.
The INTERNET, the MISinformation superhighway
