The larger tubes above the heat riser direct exhaust gasses to the intake to heat the plenum, the smaller nipple in front of them is for the tube (white insulated tube in pic below) that heats the choke; it is hot air only, no exhaust gasses.
The INTERNET, the MISinformation superhighway
