Never broke a b&m
New parts are not preventive maintenance. Flexplates break because of tire shake or vibration. Best way ti prevent flexplate problems is by checking crank centerline. It's a pita with a stock case due to having to remove pump. But, then you know.
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
