I do plan on making a smaller plate that they
mount on.. I MIGHT get it to fit on the valve
cover with the breather still in place.. it'll
be close.. also I have my regulator on the back
of the engine going across the valve cover.. I
might move that to the firewall or the inner
fender well I dont like it where it is.. I have
tilt it up every time I adjust the valves and it
gets loose tilting it back and forth
EDIT
By the way I picked up the same coils you show
in your first pick(LS type)
wave
