When I had the glass replaced on my 65 b, it leaked. The glass company ended up putting in some butyl rubber, the always gooey stuff, in the lower areas that are prone to leak issues. End of discussion on the leaks. At least there!. Butyl is what was generally installed from the factory along with the rubber gasket on the rope in style glass
