if you have the 1.4 or the 2.4 they are a multi air engines, very sensitive to oil viscosity. thicker oil will cause problems with the multi air actuators,early production engines had issues if they sat for more than a week, the engine would hard start, crank a very long time as the multi air actuator system couldn't pump up, it had no compression. there is a reason why the thin oil is called out.
