Hi, this is my first post on this particular forum. I recently purchased a 1975 440 and 727 torqueflight out of a Chrysler imperial. During stripping the engine down to the bare block, I was surprised to find the engine has little internal wear what so ever. No ridge in cylinders at all. Due to the low compression of this 440 (most likely 8:1 compression), I'm questioning what power I can make with an intake, carb and cam swap. The motor is going into a 84 dodge Short box 4x4 pickup with 3.55 gears and a auto trans. The truck weighs about 5000 lbs give or take. I would like to make 375 hp or slightly better. Any advice? Thanks for any input
