I run an FHO custom solid roller. Tim Banning said for hyd roller motor would have to come apart for machining for clearance(believe push rod and lifters. Had 2 hyd lifters blow apart due to acute angle on a couple of push rods.
He talked me going to soldi lifters asked him about street use and he said not an issue he has been using on street for years. He did say though don't cheap out on quality of lifters. I have comps not sure model /
Went with his suggestion on specs. Its 600" lift and 250 duration Street driven,528" hemi 3:73 gear 5spd. Believe he told me it will work with power brakes as well.
He says this cam will support 800hp
Worked great 2 years so far, revs to almost 7000rpm without an issue and get there quickly
good luck
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
