Originally Posted By Cab_Burge
With three build sheets, if they are not exact duplicates of each other, which one do you think is correct for that car work confused
My V code 1970 charger had a U code build sheet under the back seat also shock shruggy
They are exactly the same ..All of them
And they have the VIN and VON on all of them as well.
