Originally Posted By 451Mopar
Did you try swapping the rotors side-to-side to see if changing the drilled pattern / rotation helps with the noise?
I suspect they are marked with the intended direction. work
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
