A "moan", "buzz", "whine" noise is often caused by a rapidly cycling pressure regulator valve, the factory calls it "regulator valve resonance". It's more of an annoyance than a real problem...the recommended cure is to replace the valve body.
The INTERNET, the MISinformation superhighway
