Have any of you used the on line calc to see the air speed difference from 350 cfm to 400 cfm?I don't think you would lose 10/15 hp even on a bigger flow.A lot of that flow is above .700 but the lower numbers will still help a smaller cam/engine,rpm.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
