I ran a best of 7.27 in the 1/8 with a 360/380 hp crate motor, no NOS at 2950 lbs. That is basically a 2000 360 magnum with a .501/.513 cam with a Mopar M1 intake everything else stock magnum. I think that would be 11.40's in the 1/4.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
